Whirlpool MH6140XK Microwave Oven Logo
A
Anonymous Posted on Dec 24, 2013
Microwave burnt smell - Whirlpool MH6140XK Microwave Oven
Rag burnt, is it safe to use the micro? The rag burnt badly, there was smoke and a strong bad smell persists. Is it safe to keep on using the micro, what can be done about the smell?
Hello -
It is probably safe to use the microwave oven after removing the burned smell.
I found some methods for removing a burned smell from a microwave.
https://blog.bostonappliance.net/5-foolproof-ways-to-get-burnt-popcorn-smell-out-of-the-microwave/
(Quote)
1. Fill a bowl with 1/2 cup water and 1 tablespoon white vinegar.
  • Microwave it for 4-5 minutes and leave it with the door shut for 10-15 minutes.
  • Steam will loosen smell-causing detritus stuck to the walls. Vinegar absorbs odors, even stubborn ones like burnt popcorn smell.
  • After the waiting period, remove the bowl and wipe the inside of the microwave down with a paper towel
2. Not good enough? Okay - soak a sponge with vinegar.Place some baking soda on top and microwave the sponge for 25 seconds.
  • Wipe the inside of the microwave with the sponge.
  • Don't forget the glass tray and the microwave door.
3. If steps 1-2 don't remove all the grime, soak cotton balls with acetone-free nail polish remover and wipe down the inside of the microwave.
  • Even stubborn stains should come out.
  • Wipe down the inside with soap, then vinegar water, to remove the polish remover.
  • We recommend following through with step 4 to get rid of chemical smells.
4. Banish the remaining smells with the power of citrus.
  • Peel two oranges or slice a lemon in half.
  • Place the orange peels or lemon slices in a bowl of water (1-2 cups).
  • Microwave it for 4 minutes. Watch closely to ensure that the water stays in the bowl and the citrus peels do not burn.
  • If possible, leave the bowl in the microwave (with the door closed) for 12 hours.
  • Too time-consuming, or just not doable for you? That's okay too. Let the bowl sit in the closed microwave for half an hour then, if the burnt smell persists, continue to step 5.
5. Still bad odors in your microwave? Leave an open box of baking soda on your microwave tray overnight.
  • It will neurtalize the odor without adding to the smelly situation in any way.
  • You can also place coffee grounds from your morning coffee in a bowl in the microwave all day while you are at work.
  • If you don't mind coffee smell, you can microwave 2 tablespoons of coffee grounds in a half cup of water for 2-3 minutes to expedite the process.
(End quote)
Best wishes.
I burnet a styfoam, and plastic cover in the microwave. The smell is awful, like melted plastic and burnt wood. My entire house smells horrible. Is there some way to get the smell out.
Try pouring some vinegar in a cup and microwaving until the vinegar steams. This works well when burnt popcorn smells up the microwave.
How to gt rid of burnt smell inside the microwave from burnt popcorn
Wash with baking soda wipe out clean then wipe down with vinegar
it will eventually go away.
Burnt fish smell in microwave
Mix vinegar and water in a small container, set timer for 60 seconds and start the microwave, when it starts to steam it will bond to the interior, at that point dis-engauge microwave oven, if smell is still present open a small box of baking soda let sit for 24 hours in the oven before use.
Will the fuse in amicrowave cause the burnt smell
No! if the microwave still runs, mix water and vinegar in a cup, set timer for 60 seconds and run microwave oven until you see steam develop and turn off, this will bond to the interior walls and should solve the burnt smell problem, repeat if required.
Loud noise followed by a burnt smell coming from the control panel. Not heating up at all.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.'';
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Burnt smell in microwave from burnt muffin in a GE microwave
Many solutions are found here:
http://www.google.com/search?hl=en&q=microwave+smell+OR+odor&btnG=Google+Search
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
