C
Chad Posted on Dec 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low volume cut out
When the volume is at a low setting the sound is scratching and cuts in and out.
Audio Service Clinic
Level 3:
  • Pioneer Master 924 Answers
  • Posted on Nov 26, 2014
Pioneer Master
Level 3:
Answers
924
Questions
Helped
351328
Points
1710
I'm sorry, but Pioneer turntable have no volume control. You must mean a receiver. If you would like more information, please visit my website at audioserviceclinic.com. Thank you.
Grubhead
Level 3:
  • Pioneer Master 5,755 Answers
  • Posted on Jan 03, 2014
 Grubhead
Pioneer Master
Level 3:
Answers
5755
Questions
Helped
1661899
Points
11417
Could be a bad cartridge.
I have blaupunkt 43 "smart tv also a blaupunkt sound bar which cuts out sound when i change channels,is there anything i can do?
this is automatic protection for a blast of sound bar
and try to connect it in other output if possible
or in settings audio low the volume to devices
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Trouble with volume and current drive cuts out
Is everything cleaned, and the needle seems clean , but then it aint and clean the record real good, not with a simple brush.
But the questions gives me questions , is it cutting with scratching?
then i'd like to know your scratch unit, since some tt are too slow to scratch with. And you'll be surprised which they are..... 500dollar plus
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
1helpful
Bose 312 Sound Cuts in and out
Most amplifiers design to cut out when there is an overload, such as playing the music too loud. It helps protect the device from being damaged. If the device does it at low volume, and does it sometimes, check the wring to the speaker, something might be shorting it out intermitently.
1helpful
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Volume low when watching dvd
Not much you can do about this. The movie industry sets movies to low volume when recording for better sound. They expect you to have the equipment to boost the sound. This cuts down on their outside noise. Only solution for this is to install external speakers as I have done for my movie or TV playing (I installed a TV adapter so I could hook up a projector and display the BIG game outside) but as you say, we couldn't hear it until I hooked up external speakers.
Built in speakers not working on my HP pavillion zv5000, sound only through earphones plugged in.
Try to check your settings in the control panel sound hardware .Maybe its disconnected or there are wires that has been cut-off. Try to check also your volume settings in the task bar. Maybe its set to low or minimum volume.
1helpful
2answers
1helpful
2answers
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
