SOURCE: hp photosmart 2610
HI,
u can try to reset the printer.
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
SOURCE: Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
http://en.allexperts.com/q/Printers-1512/error-message-HP-printer.htm
Copy&paste it in a browser!
SOURCE: carriage jam error
Here is the document that i want you to follow exactly in order to resolve your issue.
CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
Please let me know the result after following the document.
Thank you so much. I remain.
adonscott
SOURCE: HP Photosmart 2610 - won't print anything
Alright..Run the head cleaning process. The printer head must have been clogging ink.
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Turn on your HP Photosmart printer if it is not already on.
Reach under the access door handle at the front of the printer beneath the scanner and lift up on the scanner and door until the assembly locks into an open position, revealing the print carriage on the right side of the printer. If replacing a used cartridge, push down on the label of the cartridge to unlock it from the carriage and then lift it out of its slot.
Remove the new ink cartridge from its packaging--holding the cartridge by its plastic sides. Pull the pink tab covering the copper-colored contacts gently down and then remove the tape from the ink nozzles.
Align the cartridge at the front of the slot in the print carriage with the label on the cartridge pointing up. Push the cartridge into the slot until it clicks securely in place.
Close the access door by lowering it and the scanner back into position.
