Question about Nintendo Wii Fit - Balance Board + Game Console
My wii balance board won't switch on, I havent used it in a few months, but used brand new batteries, nothing happens, after further investigation it appeared there may have been a battery acid leak, is there any help for my board?
    Master:
  • 367 Answers
Clean the battery contacts
Posted on Dec 23, 2013
SOURCE:
SOURCE: wii fit balance board
You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
Posted on Dec 23, 2008
SOURCE: wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Posted on Feb 09, 2009
  • 32 Answers
SOURCE: WII FIT BALANCE BOARD BLUE LIGHT WONT STAY ON
replace the batteries with fresh ones
Posted on Jun 07, 2009
lucy222
  • 111 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-76
Posted on Jul 23, 2009
SOURCE: wii fit platform does not stay switched on after
have this message came out "an error has occurred. press the eject button and remove the disc, then turn the wii console off and refer tothe wii operations manual for help troubleshooting." i tried several times, but same message pop out. izzit something do to with NTSC?
Posted on Oct 01, 2009
"communications with the Wii balance board have
Ok, that only happens when there is something blocking the signal to your Wii's antenna. Try moving the balance board further away from the television.
Dec 17, 2010 | Nintendo Wii Fit for Wii
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
What do you do when your wii balance board keeps saying please step off me and press A
Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
Mar 18, 2010 | Nintendo Wii Fit - Balance Board + Game...
I got a brand new wii fit balance board and i syncd it, put in the batteries that came with it, (new batteries) put on a cover, and its working fine. about 2 weeks later it was bought, I was playing a game...
According to the Nintendo support site, here's what to do.
Your movements are not being correctly detected
  1. Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
  2. Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
  3. Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom (such as carpet), try using the foot extensions.
If the Wii Balance Board is still not correctly detecting your movement, please call 1-800-255-3700 for assistance.
Here's the link if you want to see for yourself
http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp#movement
Jun 08, 2009 | Video Game Consoles & Games
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
My wii fit balance board won't switch on. i have tried new batteries and even bought a new power pack.yet it still does nothing.it is 6 months old
Has it always done this or did this just start happening? If this is the first time you are useing it try starting wii fit before trying to turn it on then you may have to sync it using the little sync button on the board and on the wii system,I hope this helps you, please leave me feedback as I am new to this site and am trying to build rep.
Mar 13, 2009 | Nintendo Wii Console
I have the rechargeable battery pack on in my wii fit balance board. I the power keeps cutting out and it is saying communication is lost on the balance board, and to push the power button again. This...
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Jan 27, 2009 | Nintendo Wii Fit for Wii
Wii balance board: i press the power button but nothing happens
Ensure you have fresh AA batteries installed. Ensure that Wii Fit (or any other Balance Board using game) is fully started before pressing the power button.
And, at the risk of sounding silly, ensure that the button is facing away from the TV.
Dec 30, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit - Balance Board + Game Console Logo
82 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
