Question about Viking DFUD042 Built-in Dishwasher
Viking dishwasher that does not stop draining cycle - keeps on running
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
Posted on May 17, 2009
  • Viking Master
  • 19,396 Answers
If the cycle does not stop draining that is usually because of a faulty water level sensor. The floater that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely. Check if sensor is stuck or if switch is faulty.
Some machine may use a membrane switch instead of a floater.
Posted on May 21, 2009
    New Friend:
  • 26 Answers
On the Viking, much like Bosch, Asko and others, there is a tray or sump under the machine that catches water that either leaks, or more often is the product of too much soap causing an overflow of suds. This tray as a foam block that floats and starts the drain pump. This is to prevent the washer from ruining the floor in the event of a stuck valve etc. When you tip it back it is reseting the float in the tray. A wet vac can be used to clear the tray and then you will be fine. Hope this helps!
Posted on Apr 29, 2010
    New Friend:
I have had the same problem this weekend and fixed it by looking at wiring diagram and a few troubleshooting hours, here it is , it is the float switch that is not level therefore the drain pump keeps pumping and it wont let it cycle to anything else, take off the bottom plate of your dishwasher and you will see the grey drain housing , just bellow it to the left is the float switch relay with 3 black wires coming off, all i did was put a spacer to raise the drum so that the switch shut off and leveled the housing and it worked , if you have the manual look at the wiring diagram its all there .
Posted on Sep 06, 2015
4 Suggested Answers
SOURCE:
bigg t
  • 640 Answers
SOURCE: eaton viking dishwasher
it may not be the pump.if it leaks when you run a wash cycle then the pump seal may be bad but if it only leaks when you drain it,it seems that its a drain hose/piping connection.
Posted on Nov 04, 2007
  • 11 Answers
SOURCE: Stopping the Cancel/Drain Cycle
Disconnect the Drain Hose from the plumbing under the sink and using a bucket hold the hose in the bucket and attempt to drain the dishwasher. If you have a disposal and recently replaced it, the knockout plug may be still inside where the drain hose attaches into the disposal. To determine if it is still there, using a screwdriver, stick the screwdriver into the drain hose hole on the side of the disposer and if you feel blockage then the knockout plug is still in the disposer and will need to come out. To remove the plug use a short screwdriver and a hammer and place the screwdriver into the drain and strike the top of the screwdriver once and the plug should pop out of the disposal. Be careful not to hit the disposal too hard or to damage any plumbing. Reattach the drain hose and you should be all set. When you remove the drain hose if the machine is flashing an error code, go to the circuit breaker box and turn off the breaker for the dishwasher, wait 5 mins and turn it back on. This should reset the board and the machine should operate properly.
Posted on Feb 05, 2009
  • 153 Answers
SOURCE: viking Professional Dishwasher - dfud142
more than likely the door saftey switch is broken, check your owners manual
Posted on May 12, 2011
THERE ARE NO CLOGS ANYWHERE IN THIS DISHWASHER VUD141-SS. EVERY AREA HAS BEEN CHECKED FOR POSSIBLE FOR CLOGS. DISHES ARE CLEAN AND THE WATER CYCLES FINE. HOWEVER WHEN THE TIMER REACHES THE CYCLE WHERE THE...
yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Feb 11, 2015 | Viking Dishwashers
Dishwasher keeps making suction sound though cleaning cycle is done
You made have a leak causing the drain pump to keep running, if you never worked on this unit before I would suggest you call a professional. If you have worked on this before then look for water in drain pan to unit, the reason is water has entered drain pan and caused the float to turn on pump, could be from the drain hose, leak in a hose, or the diverter. all this part are located unit unit in access area (small panel under large door).
Good Luck, I hope this helps...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 21, 2011 | Viking 24 in. Professional Series VUD040...
My Viking DFUD042 is stuck in drain cycle while fresh water is entering the dishwasher through the grid on the right side. The pump is working continuously and it only stops after I turn off the power. ...
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
Jun 23, 2011 | Viking DFUD042 Built-in Dishwasher
The red arrow keeps blinking and washer does not run, cycle starts then stops leaving water on bottom....
You either have a blocked drain line drain pump, or water is in the base pan. behind the toe kick is a base pan that will catch water if the flood switch is activated this condition will occur. I know this dishwasher very well can help you fix it yourself.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Viking VDB450 Dishwasher
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
My Viking just stopped providing water - it goes through all the
You probably have a leak, in the pump housing area below the unit, which is causing the drain pump to run continuously.
Jan 26, 2009 | Viking 24 in. Professional Series VUD141...
Eaton viking dishwasher
Nov 03, 2007 | Dishwashers
Viking DFUD042 Built-in Dishwasher Logo
5,485 people viewed this question
Top Viking Dishwashers Experts
Pierre Laplante
Craig Butler
Craig Butler
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
