Error message 1009
I went to the HP support site, and it says
'Error Message: 1009
Event: System hardware. Cause unknown
Recommended Action: Contact System firmware team'
I suggest you go to the support site yourself at
http://h20566.www2.hp.com/portal/site/hpsc/public/
Come back here if you then need any more help.
Bests, BigSteve
The particular error code (1009) is a generic error code for 'interrupted' for system recovery. Meaning, somehow, the recovery process was interrupted. For most HP machines this can be a simple as a few keys being pressed on the keyboard, a power interruption, bad disc, faulty hard drive, or some other form of read error during the process.
Unfortunately, the error code isn't specific enough to give you the best possible troubleshooting information, but I shall try to help as much as I can.
If you can provide the exact HP model number, I can provide a more specific solution for you; but, if you have a Desktop or Notebook computer that uses F11 (on start-up) to enter into system recovery, then you can do the following:
NOTE: The PC will appear to FREEZE for several minutes (it can take quite a while depending on the Operating System you are installing), so do not turn off the power to your machine. If the machine stays frozen for longer than several hours, then chances are the hard drive is having issues, or the recovery image cannot be recovered.
If you have tried the above steps, and you are still failing with Error 1009, it usually points to a failure with the recovery medium (image on a CD, or image on the hard drive), or that the hard drive it is restoring too is having a write/read error. This can be worked around if you have a USB recovery media you can use.
If you have access to another computer, you can create a recovery key on a USB stick to boot your HP computer from, and then kick off the recovery process that way.
Those options, however, shouldn't be taken unless you have tried the above solutions first.
Regards,
Phillip
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
