Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Rheem rr410T no hot water
I have not hot water, How to change my element heater
SOURCE:
  • 21 Answers
SOURCE: Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Posted on Feb 10, 2009
  • 408 Answers
SOURCE: Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Posted on Mar 07, 2009
  • 687 Answers
SOURCE: No hot water, Rheem Model RR612T, Electric Hot Water Heater, 60 g
If you don't have current, 0v from terminal to terminal, then you don't have voltage to the elements. Replace the thermostat but check that you have 220v to the thermostat. It is possible that your breakers to the unit are either bad or tripped.
Posted on Apr 07, 2009
  • 234 Answers
SOURCE: I have a Rheem EcoSense hot water heater and all
Have you try to reset the power to the heater?Then turn the hot water facuet on to see if it will start up.
Posted on May 02, 2009
  • 7 Answers
SOURCE: My Rheem hot water heater stopped putting out hot
If you are not familiar with the element, I would get someone that is familiar with one and have them do it. It's not something I would recommend you do based on your question. There's electrical, pressurized water tank, and a whole lot of water that may cause you to have a worse bad day.
Posted on Jun 26, 2009
I changed the heating element and still no hot water on electric water heater.
The element is not receiving power. Check the power source to the hot water heater and the element and thermostat operation.
Mar 20, 2017 | Water Water Heaters
HOW DO I CHANGE THE HEATER ELEMENT
http://www.bing.com/videos/search?q=how+to+wire+a+double+element+hot+water+heater&qpvt=how+to+wire+a+double+element+hot+water+heater&FORM=VDRE
Jun 01, 2015 | Element Water Heaters
Hot water recover time
No.
Fold-back elements are low-watt-density, so element does not burn out as easily since heating is spread across more surface area. But recovery remains 16 gallon per hour.
20 amp breaker and 12 gauge wire: max 3800 watts
30 amp breaker and 10 gauge wire: max 5800 watt.
4500 watt element heats 20 gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Instead of changing elements: Set thermostats higher so more cold is added to hot water, and then you have more hot water available inside tank.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 04, 2014 | Camco Copper And Zinc Standard Hwd Water...
How do i change the upp and lower heating elements
Copy following link for step-by-step
You might want to test them first.
If water heater has some hot water, then upper element is good.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If elements test good, then problem can be thermostats.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Oct 11, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
MY Rheem 81SV40D Water Heater (47 gal) does not heat enough water. Approximately one bath worth.
You have dual-element 240Volt electric water heater.
Since you have some hot water, then we know upper element is good, and that circuit breaker and electricity to water heater are good.
Not enough hot water is probably bad lower element, and possibly sediment build-up in bottom of tank.
Test element:
Replace 4500 watt element available at local hardware, and clean out bottom of tank:
Oct 07, 2012 | Rheem Tankless Hot Water Heater...
Need to know the year of my tank RR410T
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Mar 02, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem electric water heater 50 gallon, lukewarm water. Water is warm but not hot, where should we look for problem?
Luke warm water is the result of top element bad and the bottom is the only one heater. The best solution I can reccomend is to change both out due to the fact the bottom element may go bad and since you have to change one you might as well change both.
Turn power and water off, drain heater down and once water is drained out change them out. Once new ones installed turn water on to fill heater and open faucets and get air out on the hot side of each faucet once water is flowing out of each faucet you are now ready to turn power back on.
Oct 12, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Only warm, not hot water from our tap unless I slow the tap down.
Warm water indicates a element is probally in need of replacement. For warm water only more than likely the top element is bad. If you get a burst of hot water for a little while then your bottom one is probally gone bad. Best to replace both elements when changing one out due to not being to exspensive and you have to drain it down anyway.
To change out shut water of and turn power of to water heater open hot side on a faucet to allow heater to drain down so you can change out element.
Jul 27, 2011 | Water Heaters
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
175 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Thomas F. Schneider
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
