SOURCE: My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you Repeat until the walking belt is centered.
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
SOURCE: the walking belt is slipping and drive belt
You will need to replace the drive belt inside the motor cover. and also tighten the rear roller bolts to tighten the walk belt
SOURCE: I have norditrack c1900 series
Watch this videos:
http://www.youtube.com/watch?v=JC72OIKdluY&feature=related
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
