SOURCE: My Dremel Versatip wont melt the solder - it gets
Christina, It's probably dirty, and dirt is lousy for transferring the heat from the tip to the solder. With the iron hot, wipe it on a wet rag. This should immediately remove the black crud and make the tip shiny. Keep a wet rag handy to do this often if you are soldering for more than a couple of minutes. If the crud is too bad, you can use a bit of soldering flux on the tip, then the wet rag. If that doesn't work, you can file the tip (easiest when it's cool) until you have copper showing all around the tip. Please vote if you found this helpful. Good luck, Al K
Testimonial: "Thank you! very helpful - I'll try all you suggest. You are very kind."
SOURCE: i can't find instructions for dremel versatip to
These aren't the instruction for the Versatip. Try here.
http://www.axminster.co.uk/downloads/701839_manual.pdf
The tips just unscrew using one of the small spanners provided.
