Try unplugging the oven for about 30-45 minutes. Plug it back in and see if the door will open. If not, you have a bad latch, interlock microswitch or control board.
On most of these ovens, you can either unplug the unit or flip the breaker from the main and keep it off for ten minutes, then either plugs it back in or turn it back on, and then hit and hold the start/cancel button on the control board for twenty seconds. Yu should hear a beep and then you should see the display light up and ask for you to set the time. If it does this, then the reset has worked. If so, put the oven into a self clean cycle and hit start, listen for the machine to come on, and about a minute later cancel the cycle and see if the door unlocks. If that doesn't work, you may have a bad door lock assembly and you will be forced to manually unlock the door.
To manually unlock the door, stick a screwdriver or heavy wire coat hanger in between the door oven and the door lock and see if you can disengage the door lock. If you manage to get the door open, leave the door open and put the oven into another self clean cycle. If after hitting the start button to activate the self clean cycle, you notice the door lock either not moving or getting stuck closed again you will need a new door lock assembly. If after hitting the start button, the door lock seems to be working fine, the door lock had probably shorted out during the cleaning cycle and looks to be okay now.
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Hi, Seems like you found out the hard way what I wrote about in this tip... Check it out it also contains some thing to try on how to unlock that oven..
Unplug the unit or shut off the circuit breaker for 5 minutes.
Plug the unit back in or turn on the circuit breaker. Set the clock and gently
try moving the door lock lever (is so equipped) or opening the door. or Set the self-clean cycle again and only allow it to work for 15
minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try
moving the door lock lever (is so equipped) or opening the door. If these
procedures fail to correct the condition, the lock must usually be accessed and
moved manually to open the door. Some model
ovens require the oven door to be manually unlatched before the controls are
returned to the OFF position or else the door may not be able to be unlocked.
Check the owner's manual for proper operating procedures.
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
