Just loaded new software and registered Trying to activate my dongle, but it says can't read. My computer is Windows 7; but I downloaded drivers for window XP
SOURCE: Loaded 3D Embroidery software on
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
SOURCE: new computer does not recognize dongle
I've just found the UK site for Husqvarna -www.husqvarnastudio.co.uk/updates.html - and have successfully downloaded a dongle driver. Their site has some very useful info. Good luck and happy stitching. Cheers.
SOURCE: Husqvarna #1+ Dongle Not working with my computer.
You probably need to install the XP drivers for the dongle. I don't have the exact website at my fingertips (brain tips?) right now, but if you visit Jan Henning's Sew Much 4 Retirement website I think she has it amongst her Tips section. I had a similar problem years ago, but solved it by putting the installation CD into the computer, not running the automatic Install, then opening the program. It then goes looking for the dongle driver on the CD. This solution does not work for everyone, some need to download the drivers off the internet.
SOURCE: Loaded autodigitizing onto our new computer with
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
SOURCE: I have a Designer 1
Those floppy drives that require a dongle are really no good. The USB floppy drives are the way to go. Just plug and play. Here is a link to the USB floppy drives if interested. They start at around $8.00. If you want to stick with the floppy with the dongle, you might want to try running windows update. I didn't see where you posted the maker of the floppy drive or the dongle so getting the drivers or software is pretty much impossible.
