Hi i have a lexmark x3470 printer that even when there is no paper in it it comes up with clear the paper jam...i cant find any paper in it..
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Buy an HP!
Lexmark phantom paper jam. The paper jam microswitch might be stuck open. Unplug power and push up microswitch as per instructional vide at:
http://www.metacafe.com/watch/1316324/fixing_lexmark_p6250_paper_jam/
Tardsfreakazoid's Channel
I have a printer and it did a paper jam and i dont kno how to fix it
I keep getting clear paper jam, but there is no paper jam, how to fix it
I have unplug the printer looked inside and out and there is no paper to be found anywhere.I have removed the ink jet still there is no paper to be found.
I have a X3470, I fixed the Cover Switch thanks to this site. But now only one side is feeding paper, it states no paper and causes a jam?
its crap. warranty
I have the same problem with the x3480. I had the 'open cover' problem which I fixed by taping up the switch at the back but now only one side is feeding and there is a permanent paper jam error.
So far Lexmark has told me that this is a "rollers are defective since it is not feeding the paper in" issue. After an hour of cleaning, resetting, ect. the paper still jams on load.
my lexmark x3480 printer has a phantom paper jam - there's no paper in there but it keeps telling me theres a paper jam when there isnt and so i cant print anything. please help! If theres any paper in the printer it just spits it out and still says theres a jam!
Same deal. It reports a paper jam when there isn't one.
I have a X3470 that had a jam, wont feed the paper and when it does, it pulls off to the right side. How do you fix this.
there is no paper in the printer but th epaper keep jamming while the paper beeing printed.
Well I have a lexmark x5470 and my brother caused a paper jam but the problem is their is no paper inside the printer or anything like that. so what can I do to remove the paper jam warning when turning the printer on for use.
