Question about Canon FS400 Camcorder
Cannot record movies on this memory card - Canon FS400 Camcorder
Canon eos t5: movie recording has been stopped automatically appears after only 10 sec. of recording
This could be something to do with the size and class of your memory card. You usually need a class 10 card for the higher read and write speeds.
Feb 20, 2015 | Canon Cameras
How do i record to the memory card instead of to the built in memory?
During playback, use the joystick to select the tab corresponding to the type of recording you want to play back movies and photos and where they are recorded as well. Whether by the built in memory or a memory card.
Happy shooting!
Jan 12, 2011 | Canon Vixia HFR10 Camcorder
Is the memory card removale
Yes, the memory card is removable. The following web site gives different cards.
http://support.nikonusa.com/app/answers/detail/a_id/16778/~/approved-sd-cards---coolpix-s4000
The following is a list of approved memory cards for the Coolpix S4000 digital still camera. These cards have been tested and approved for use with the Coolpix S4000.
The S4000 uses SD (Secure Digital) memory. Memory cards with an SD Speed Class1 Memory of 6 or faster are recommended for recording movies. Movie recording may stop unexpectedly when memory cards with a lower Speed Class rating are used.
SanDisk 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 TOSHIBA 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 Panasonic 2GB2, 4GB3, 8GB3, 12GB3, 16GB3, 32GB3 Lexar 2GB2, 4GB3, 8GB31 Specification defining minimum data transfer speeds for SD and SDHC memory cards.
2 If the memory card will be used with a card reader or similar device, check that the device supports 2 GB memory cards.
3 SDHC Compliant. If the memory card will be used with a card reader or similar device, check that the device supports SDHC.
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Jan 06, 2011 | Nikon Coolpix S4000 Digital Camera
I have two sd cards that are brand new on is a pq1 4GB sd hc and the other is a pny optima 2GB sd when I put them inmy camera it says filesys e00100 what is it?
I own a Nikon D5000, that has a 'pqi 4GB SD HC' memory card inside.Within this camera is also something called movie mode, in other words I can record short movies. Now here is the problem, Nikon says how much I can record on the memory card, depends on the speed the memory card records. According th them, I can only record 5 minutes on a 2GB memory card. Does that sound right to you. P-l-e-a-s-e I need help in understanding this.
If this is true,......what side memory card (HD if possible) would I need to record 30 minutes in the movie mode. Thank you so much for your help.
May 16, 2010 | Cameras
I can't record more then 20 sec video file
I'm sorry to inform you but after researching your camera only records for 20 seconds. It has nothing to do with your card. Only 20 second blocks of time.
Movie mode - The total amount of recording time available is shown by the green "00:20" in the lower right hand corner. This is SHQ 640x480 resolution at 30fps, the maximum recording time is 20 seconds. In the lower quality 640x480 @ 15fps or 320x240 size, the recording time is limited only by space on your xD card. The shaking hand icon indicates that we have the image stabilizer turned on.
Oct 04, 2009 | Olympus SP-560 UZ Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Can I use the SD memory card to record movies?
No: SD memory card id only for the digital still photo.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Canon FS400 Camcorder Logo
55 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
