It really depends on the model of Powershot camera you purchased if it can shoot Raw format or not. I jbelieve the only model available currently that can is the Powershot S120 & G16, the older ones cannot. You can check your models capability at DPReview.com for more information on your camera model.
SOURCE: canon 20d raw to pc
Have you ever been able to view the pictures on your pc?
Have you got a card reader that can view the card contents externaly from the camera?
I found the Canon software is quite as happy from a card reader as it is reading from the camera. (I have the next model up, 30D.)
Have you tried upgrading your software, or tried using a third party image program to read the raw files?
Over to you!
SOURCE: Raw images on a Canon Powershot A710 is
Yes, it is patchable and RAW is possible:
http://chdk.wikia.com/wiki/Main_Page/
SOURCE: Canon Powershot A610 won't power-up
My camera stopped working some time later after being dropped.
If you are brave (or desperate), try this... I found it was not too difficult to open the camera up. Take all the screws from the bottom, sides and under the card and usb, and inside the battery compartment. They are all different lengths so keep some record of what goes where. Then I made sure the multiway connector underneath the top was firmly in place. That was all I could see that I could fix myself. And what luck! when I put it back together it worked.
SOURCE: Camera set to RAW, but pics showing up as JPEG when viewed,stored
Some cameras will shoot RAW + JPEG, and save a copy of each in a different directory on the card.
Re-check your owners manual, and also check the manufacturer's website for a firmware update...
SOURCE: When I shoot in Raw + jpeg, no raw filkes show up.
I had the same problem, basically all you need is a RAW converter, the canon software should do and should be provided with the camera and if you havent got that then there is a wide selection of free software on the internet im sure of it just search for it, or a lot easier not to use RAW in the first place...
