The temp alarm goes on on the display and a flute sound with it please advise the car is a 2007 c320cdi with 106 thousand km on the clock. Please Advise
Check the battery in the vehicle and the battery in the actual keyfob itself. Sometimes when one of these are low the alarm will randomly sound. The random alarm sounding is typically an indicator of a low battery somewhere. What is the year make and model of the vehicle? Some, like bmw's, have sensors under the hood, on doors and windows that get stuck and randomly sound the alarm. Please Advise
HI, My prado 1999 4V 2.7CC 4WD M/T, my car is vibrating on high way after 100 km speed, please help me for sending solution of fault. upto 100 km speed its runs smooth but after 100 km it start vibrating all body and interior.
other problem is for tires the one i purchase this car he replaced the four tires of the car by size 205, 70,16R actual size is 215,70,16R or 265,70 R16.please advise it is ok no problem to drive on present tires,
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
My friend that is your engine being very hot and crying for help, this is very serious and could cause complete engine failure. Do not start the car or attempt to drive the car it will need to be towed to your service shop. If damage hasn't already occurred the problem could be stuck thermostat,bad water pump, blown head gasket or a leak in one of the water hoses or radiator.
My toyota has 297 thousand miles and runs like a dream,, CV joints and axels were replace on mine at 200 thousand,, I think it was well worth it to do mine
check to see if your radiator is clogged and needs to be flushed and back flushed or check to see if the waterpump is operating correctly and if it is check to see that if the thermostat is stuck shut
