Question about LeapFrog Leapster 2 Learning System
My daughter has a Leapster 2 (pink) hand held game. We can not get it to sign into her name, so she can not play games. Can you help?
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck ....thaks to Nicksdad who posted this response to a previous post. Worked for me...try it.
Posted on Jun 05, 2009
SOURCE:
I turn on my daughter's Leapster 2. I sign in. I click "Cartridge Game". The screen goes black & then It goes back to the "Leapster 2" screen, followed by the "if you...
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
Jun 08, 2011 | LeapFrog Leapster 2 Learning System
My daughter's Leapster 2 Handheld game's screen is dark. She cannot see any of her games that she tries to play. I tried using the brightening button, but it doesn't help. Also, have replaced the batteries...
are the batteries you are using the correct size/voltage for the leapster? I believe it takes 4 AA/LR6 size batteries at 1.5V each.
has the product been dropped or bashed?
May 04, 2011 | Leapster 2 Handheld Game
Deleting Leapster 2 profile names
Here's the solution: http://answers.yahoo.com/question/index?qid=20081228233009AA2w5Xx
Nov 11, 2009 | Leapster Learning System
Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Apr 06, 2009 | LeapFrog Leapster 2 Learning System
How do you delete existing profile in Junie B Jones Leapster game
To delete a player profile, go to the player profile screen and press and continue to hold down the following buttons in sequence: Home
A button
Left arrow
Then, touch the X icon that appears at the bottom of the screen and follow audio instructions.
Note: You can only delete a name when all three name slots are filled.
The above procedure only works on LEAPSTER 2.
Directly from Leapster website -
Question How do I delete or change a player name on Leapster™ cartridges? trnsp.gif Answer It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
This is a design flaw with leapsters games (apparently nobody thought to think that they do get sold secondhand or passed down in families)
Since you havent specified the system -
LEAPSTER ORIGINAL
LEAPSTER 2
LEAPSTER LMAX
Clicking on any of the above will get you the owners manuals in PDF format.
Thanks for using FixYa - if you need more clarification on your question, please reply to me first.
Thank you.
Apr 04, 2009 | Leapster Electronic Book: Junie B. Jones...
Owners manual
how do I remove the names that were originally put in and add my sons name to the leapster 2
Jan 04, 2009 | Leapster Learning System
Pink lmax does not work
Have you followed up all the OM instructions (e.g. full charge, how to turn on very first time, etc.)?
Jan 25, 2018 | LeapFrog LeapSter L-Max Console
Broken Leap Frog Leapster Learning Game System
I purchased a Leapfrog Leapster in end of June sales last year for my daughter's birthday in October 2008. When she first turned it on it froze but after restarting played fine for 2 hrs then died and refused to work again. Fortunately I had kept my receipt (Target) but was still worried about it having been 4 months prior. They ended up giving me a store credit as they no more in stock at that store and I picked one up from another Target without having to pay the difference between my original sale price. I know you don't have the receipt but you could contact the place of purchase and ask them even if they are able to send off for repairs or put you in contact with the right people. Hope it helps a little ...
Nov 16, 2008 | Toys
LeapFrog Leapster 2 Learning System Logo
397 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
