This is probably the most common error faced by Android users. This error is not critical and will not harm your android, it can be very annoying when the messages pop-ups continuously and says, "Unfortunately, Google Play Services has stopped working". So if your facing that error, and are unable to troubleshoot the problem, Here are your answers to the fix, and resolve your issue. So let's get started with all fixes to solve the error.
Reasons
Almost every kind of Playstore error occurs due to the Network issue, or any hardware or software issue. The main reason is Play Store is hard-wired with a specific device, and it may happen that accidentally Google has rolled out a wrong version of Google Play store in your device.
Before You Start
Before proceeding with the fixes, let's have a look at some short-tips that can help you in coming out from the issue as well, If any of the below-mentioned things happened with your device, so firstly perform these short-tricks. In most of the cases these short tricks solve the problem
- If the app is crashing so frequently.
- If the app isn't opening.
- If the app doesn't respond.
- If the app isn't working properly.
Try these small tricks, to fix the issues
- Refresh networks.
- Reboot your device.
- Check application is updated.
- Check for the Software or Android update.
- In this case of Google Play Services, try uninstalling the updates.
