Unplug and cease using this as you are exposing yourself to electro magnetic radiation. The door switch may have failed, you will need to disassemble the front panel to access the switch which is located within one of the holes that he door's hooks insert into and depresses to inform the control board the door is closed and is safe to operate.
SOURCE: GE Profile Spacemaker 2.0 Microwave
If
it goes dead or blows the breaker or GFI when you plug it in or open or close
the door, then there's a problem with a door switch or door switch
mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. Other times, it's a broken tab on the switch
holder, allowing the switch to rotate just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
troubleshooting & testing.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: MIcrowave doesn't heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fdyjhd
