The person i am speaking to cannot hear me talking
SOURCE: Callers can't hear me speak
This is because the microphone in your phone got disconnected in some way. Probably a faulty contact. This is a known fault for some motorola phones. The solution would be to go to a service center and ask them to check your microphone. It isn't an expensive repair at all. They will be able to do this for you in about half hour or so. It is the safest way to do this, otherwise you will have to dissasemble the phone yourself and check the microphone.
SOURCE: People cannot hear me.
this happens when the microphone is gone or if it is in loose contact ...
if you are good at opening the handsets then just open the handset check for the condition of microphone first ......then check the microphone is it touching the circuit board or not ... if the microphone is not touching the board then make it to touch it ...
check for any obstacles near by there & clear it if necessary ..
if the microphone is damaged then just get the new one which suits your model & replace it ...
this solves your problem ..
if you are not good at opening then just contact the technician
he will do it ...
it is just a matter of very little bucks ...
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
