Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
A
Anonymous Posted on Dec 22, 2013
Zanussi zdt105 reset computer - Zanussi 23 in. ZDT6252 Built-in Dishwasher
How to reset zanussi jetsystem programme function board with error E40
E40 is a door lock fault code, you need to replace the door lock,
you cannot reset the fault code, this happens automatically when the fault is rectified. nice easy job though.
1helpful
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
2helpful
What does e60 mean on a zanussi
E60 - Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Checked the electrical installation already twice to ensure adequate voltage and grounding.
Hope helps (remember to rate and comment this answer).
Reset button
your heating element may have burned out
Changed belt on zanussi tc 482 w
heater in Zanussi tc7103s not working . stats and element ok. cant locate reset button
2helpful
Error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
4helpful
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
