Rangemaster Classic 90 (Electric) Kitchen Range Logo
Murray Stevenson Posted on Dec 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock / oven not working
Clock is not illuminated and ovens do not come on. Grill and ignition are working (ie. there is power).
stargajzer
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Dec 22, 2013
stargajzer
Expert
Level 2:
Cheetah:
Answers
79
Questions
0
Helped
24288
Points
144
The display control board may have failed, check for 110v at molex connection, next look for a circuit fuse on the control board. If the above is good, replace control board from eBay.
5 Related Answers
Anonymous
  • 331 Answers
  • Posted on Aug 11, 2007
SOURCE: clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
Anonymous
  • 2712 Answers
  • Posted on Apr 20, 2008
SOURCE: range control panel
Hello maud2,
Not sure if this will help, but here are the user manuals in pdf format for your cooking range (not sure which version you have):
Classic 110 All Electric Ceramic
Classic 110 Gas
If your clock is totally melted, then as my friends above have suggested, it is best you contact Rangemaster or a competent local serviceman and have them replace the timer panel. This will prove to be in your best interest, after all.
Wishing you all the best and good luck,
IrishDruid
Anonymous
  • 6 Answers
  • Posted on Apr 25, 2008
SOURCE: how to use the ovens without the clock
If your clock is not working we can repair it for you.
www.appliancetimers.com
Howard
Anonymous
  • 3 Answers
  • Posted on Nov 24, 2008
SOURCE: rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Anonymous
  • Posted on Jan 06, 2010
SOURCE: new applaince can't set clock, cannot switch on
I'm sure you must have had an answer by now, but just incase anyone else has the same issue. The ovens don't work unless the clock has been set (happens after a power cut). To set the clock you need to hold down the left-hand two buttons (underneath the clock) and at the same time press either the + or - button.
How to bypass broken clock on eurolec 720ef electric wall oven
If you bypass the clock, how will you maintain a steady temperature, include safety features, or program functions?
What you seem to want is an outdoor grill. DO NOT bypass the logic board on your oven, sir. Help Me Find My Model Number RepairClinic com
Jun 14, 2016 • Ovens Ovens
Bottom oven stopped working. Clock display is totally blank but we have power to the oven as grill & top fan still coming on.
No make or model all pretty much the same oven power fed from clock/control either and open fuse feeding power to clock or bad clock have seen burnt wires going to clock
Apr 03, 2015 • Ovens
No power to the double oven but the hob still works
The double oven will only work if a time is set on the clock. Any time will do, you just have to set a time. The grill/top oven is independent of the clock. If the clock is faulty espare can sorce them for you.
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
How do i work the grill?
2answers
No power to digital clock on cooker or lower oven. Top oven and grill working fine. Please help! Thanks Kate
unplug and reset the clock. Could be a power surge at night. Reboot the curcuit board like yo do the computer...
1helpful
Timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
