My bobbin thread has started making a "bird nest" below the plate. I took the cover pieces off to clean it and when I put everything back on, I had this problem with the bobbin getting tangled up. Then an error message about the safety mechanism.
Try these suggestions and see if they help
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
SOURCE: not picking up the bobbin thread
Make sure the needle is facing the right way. If it's in backwards it won't pick up the bobbin thread.
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
SOURCE: my ellure machine has got
I have 1994 airostar van 4.0 spark knocks on regular gas also scaned sead had slow injector puls
SOURCE: balance wheel locked on crafter's choice
try this site and see if the download gives you a troubleshooting code.
http://www.babylock.com/downloads/instructions/?Update_ID=95
Babylock.com has really good cust. service, but your dealer should know what steps to take to clear this code.
If the sell an addtional information book on your machine, and stitching BUY it, it was so worth my $70 for my Evolve book (200+pages of HOW to's for that 8 thread monster!)
I hope this helped
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
