Question about Pride Mobility Products Jazzy Select
Pride Jazzy Select batteries not charging
My wife and I just bought this scooter off eBay and were informed the batteries won't charge. We have the original charger and I have tried to charge them, but the charging light does not come on when the charger is attached. I removed the cables to check the voltage and one battery is reading around 5.5 volts and the other around 5. Evidently the previous owner just quit using it and hasn't charged the batteries for quite a long time. The seller had the charger tested and was told theere were not problems and it was working properly. Is it possible to use a car battery charger to try and salvage these batteries or does it appear they need to be replaced? Would appreciate any assistance you can provide. Thanks!
  • 4 Answers
If you use an automotive charger you have to charge each battery individually as they should be 12vdc hooked in series.
Clean contacts and assure yourself that each lead is charging properly. Jazzy has many different models so it impossible to know which you have. But there should be some info on the charger to tell you if your output is 24v or 2-12volt DC leads.
Jazzy has a web site and there is a member section where you can ask questions.
Posted on May 17, 2009
SOURCE:
What is the voltage and amperage that i would use to charge my jazzy select elite it did not come with charger
24 volt - 3 amp
Buy one SPECIFICALLY for it.
Jazzy Select Elite Parts - Jazzy Parts - All Mobility Brands - Mobility ...
https://www.monsterscooterparts.com/mobility/mobility-brands/jazzy/jazzy-select-elite
Items 1 - 72 of 72 - Order the Jazzy Select Elite Parts from Monster Scooter Parts, and know you ... Battery Charger Power Cord (IEC C13) for Mobility Scooters and ...
Amazon.com : 24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger ...
https://www.amazon.com/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6 Rating: 4.5 - ‎42 reviews
Amazon.com : 24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger : General Use Batteries : Sports & Outdoors.
Pride Jazzy Select Elite and Jazzy Elite Battery Charger
https://atozwheelchairs.com/pride-jazzy-select-elite-and-jazzy-elite-battery-charger.html The Jazzy Select Elite and Jazzy Elite 6 Battery Charger is compatible with models with serial numbers beginning with JB3. It is an offboard charger that fully ...
Jazzy Select Elite Replacement Parts ' Battery Charger » Charger ...
https://www.southwestmedical.com > Replacement Parts > Pride Mobility
Battery Charger » Charger Assembly - Off-board, For S/n Begin With Jc1 replacement parts for the Jazzy Select Elite.
Pride Mobility Jazzy Select Elite Wheelchair and Mobility Chargers at ...
https://www.batteriesplus.com > Chargers > Wheelchair and Mobility > Pride Mobility Pride Mobility Jazzy Select Elite Wheelchair and Mobility Chargers from Batteries Plus Bulbs. Deep cycle chargers for electric power wheelchair and personal ...
Jazzy Select Elite and Jazzy Elite 6 Battery Charger - Care Motion
https://caremotion.com/.../pride-jazzy-select-elite-and-jazzy-elite-6-battery-charger US$105.00 - ‎In stock
A 24V 3AMP charger for for Pride Mobility Jazzy Select Elite and Jazzy Elite 6 powerchairs.
jazzy select elite charger Google Search
Aug 02, 2018 | Elite Health & Beauty
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
Battery runs down plug in charger and charger indicates battery is charged within 1/2 hour. use scooter and within hour battery show low again
The battery is not taking the correct charge and is in need of replacement. Put a brand new battery in there and the problemo will be gone!
Sep 02, 2015 | Pride Jazzy Select Elite
What does it mean on 1122 jazzy when the two red lights blink
JAZZY 1122 - Pride Mobility Products
www.pridemobility.com/...manuals/...jazzy/.../au_jazzy_1...
Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
Jul 31, 2015 | Pride Mobility Jazzy 1122 Electric...
Why does my chair show a full charge yet after only a half a block it will show only red flashing lite indicating needing charge.
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Apr 28, 2015 | Pride Jazzy Select Elite
After charging my wife's Jazzy Select 6, all lights come on after power up. However, when the scooter runs for just a few minutes, it drops to 4 lights on and then goes to 3 lights not too long a
hi, well that sounds like the batteries have called it a day,
If possible try another charger because sometimes the problem can be created by the charger not charging properly or the problem with the batteries being made worse by a dodgy charger.
Regards
GeWiz.
Mar 02, 2013 | Pride Jazzy Select 6
Just bought sed Jazzy Select for my wife. Chair appears relatively new. No leakage or corrosion on batteries. Charger indicates full charge but within two minutes of operation both green lights on joy...
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
Oct 24, 2010 | Pride Mobility Products Jazzy Select
MY SCOOTER WANT CHARGE UP
I'm a certified repair guy for Pride.
If the meter in back of the scooter has no movement when you plug in the charger then , your batteries are dead
Oct 04, 2010 | Pride Mobility Products Jazzy Select 14 XL...
Pride Mobility Products Jazzy Select Logo
4,492 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
