Precor 935 Premium Series Treadmill Logo
A
Anonymous Posted on Dec 21, 2013
Removing a user I'd password from a precor 935 2005
I need to remove the user ID so we can just go on without password. How
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Nov 07, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514828
Points
111994
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
How can renew my id and password
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer. When it shows the list of user profiles, click the user whose password was disabled.
You should be able to log in without a password.
also
Click the "Start" button.
Double-click "User Accounts."
Select the user account you wish to change.
Select "Change My Password." If you wish to remove the password, select "Remove My Password."
also
Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password.
Just click In New password and Confirm new password, type the new password by just clicking, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer.
You cannot change your network logon password in User Accounts.
To change your own password, press CTRL ALT DELETE and then click Change Password
tip
Forget Administrator password
if you forget the administrator password in your PC, you need not to repair the system. You are having one simple software and some simple steps to remove that password . "Offine Windows NT ". This softawre will do it for you. You need to download the software from internet . You will get a ISO image. You want to burn that into one CD and make it to bootable. Insert the cd and restart the system. This will go the command prompt.and follow the steps then it will display the users in that system .In that you will get the option to remove password. . After removing you can run the system without password.
In this you are having lot many advantages. You need not to reinstall all softwares. ou can save time . And any user's password can be removed by this...
hope this will be usefull information....
on Dec 10, 2009 • Computers & Internet
How to unlock safety code for precor 9.35 treadmill
• Set User Name
Procedure
What is the password the get the precor 3.1 treadmill to work?
• Set User Name
Procedure
I have a Canon immagerunner 22706. How do I bypass the user id and password to begin printing without entering the user id and password. Thank you
To be able to bypass the user id and password and start printing. You have to first uninstall the printer/hardware from the control panel of your computer.
Install the printer back, then while it is running it asks if you want to use a user id and password, do not accept the user id and password mode, select the option that does not require a user id and password.
After doing this, you will be able to print without user id and password.
Take care
3answers
I applied for internet banking for SBI. Then SBI send me a letter writing my User ID and password. When i try to login using these numbers, I could not open. Is there difference between User name and User...
  1. your account may not active .please contact bank for further information.
(note: the activation of the internet banking may take 3 weeks. be patient . ) user ID and user name are not different. you can also change your user name and password after login to your account.
important:please don't tell to others the username and password. SBI never ask to you to specify your username and password.
2answers
My daughter cannot remember password. is there anyway to override it or get into the computer to reset it without a disk password reset
You can try the below option.
1. If the computer is in a domain, reset the domain user is and log into the computer.
2. If not part of a domain, login using any other user id (if exists) and reset the password for your id. 3. No you are the only single user, then reset the password if you've created any password reset disk. 4. If none of the above works, then the only option is to install the operation system once again. This will not affect any applications installed, if you are not formatting the disk before you install. Just install upon the existing OS.
Once logged into OS, then disable the password option from control panel -> users and accounts. So that it wont prompt for a password while logging int next time.
Please come back and vote for me, if this turns to be helpful for you or also if you need more clarification. Thnx
Prevent K9 Filter bypassing
1. Add a password to the 'Administrator' account.
2. Add a password to each "administrator-level" account.
3. Create a "limited-user" account.
Tell the user the ID/password for that "limited" account.
Do _NOT_ tell the user the ID/password for any "admin" accounts.
Do _NOT_ let the user boot the computer from a CD, or from a USB memory-stick.
Do _NOT_ let the user physically remove the hard-drive, and then tamper with the files while it is connected to another computer.
1helpful
2answers
81003002
If you are sure you have the correct password, I would start with changing your user name that you are signing in with. Sometimes yahoo seems to want the "@yahoo.com" with the user name, and sometimes it does not.
If adding or removing the "@yahoo.com" part of the user name doesn't help, go through the "forgotten user name and password" steps.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
