I'm having trouble finding two last drivers for my "Mach4 845PE-ANT motherboard" I had my hard drive crash, so I had to Install a new hard drive. Needless to say, I had to re-install windows also. These two drivers are the last I need.
1.) Scsi Controller
2.) Multimedia Audio Controller
If anyone can help? I would appreciate it big time...
Thanks
Jeff
Ok, I went to Intel and download what you said....I even re-started my computer....But, in the device manager both the scsi and multimedia Audio controller's are still a problem....Any other ideas?Ok, I went to Intel and download what you said....I even re-started my computer....But, in the device manager both the scsi and multimedia Audio controller's are still a problem....Any other ideas?
Here is the link for your audio driver http://www.ecs.com.tw/ECSWebSite/Downloa...
I will find your scsi driver later. Let me know
Here is the link for your audio driver http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=151&DetailName=New&DetailDesc=A907%20%20(VD)&CategoryID=3&MenuID=88&LanID=0
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Check the motherboard specification for the largest capacity hard drive the BIOS can support.
A BIOS upgrade may allow you to install a larger hard drive.
You can use a large capacity external USB hard drive or install a second hard drive in your computer.
usually, the driver will not install if it is not compatible with your OS. Make sure the chipset driver is already installed , then try to delete the downloaded driver, then download and install the correct driver again that is compatible with your OS. it may also help to install it in safe mode. the drivers can be found here: http://www.biostar-usa.com/mbdownloads.asp?model=p4m80-m7
If you are using a SP2 XP or Vista installation disk, then the SATA drivers are usually not needed as both have the drivers built in. SATA is far better to use for your hard drive. If perchance the drivers are needed, they should have come with your motherboard but I highly doubt they will be. I haven't had one yet in a new installation where the drivers were needed.
Thanks and please take a moment to rate as fixya. Thank you.
i advise you to try and download driver magician from any torrent sites. if your lucky, youll see that and that will be a great help in locating your motherboards drivers.
After finding the drivers for your mb, download the audio driver and install it, it will remove your yellow icon with actual component which you have...... enjoy..:))
I have a sandisk cruzer, titanium 512mb. Model: SDCZ3 512 I have used this to store massive amounts of data that I frequently need to access. Recently, when I plugged the device into my computer's USB, I received the following message: "USB Device Not Recognized" After double clicking on this message, I got the USB Root Hub. The last item on the tree stated: "Unknown Device." I double-clicked on the unknown device, and in the Device Status box, received the following message: "No Drivers installed for this device.If you are having problems with this device, click Troubleshoot to start the troubleshooter." I attempted to troubleshoot, but the device remains unrecognized. How can I access the data I have stored on this device? I have even tried to install the drivers automatically, but it would not istall succesfully.
please double check that link....That doesn't take me anywhere..!!
