SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
SOURCE: dont have a problem I am looking to by a VTech
Yes, there is an on/off for the answering machine portion of the phone. On default it's set to off til you set your settings and record your greeting.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: Phone calls are not going to the machine
when I make a call it says my mailbox is full this is not true how can I fix this
