I have extracted the legend of figure 5B of the installation instruction here for your reference:
Remove handle from the faucet by loosening set screw (1) and pulling off handle. Once handle is removed, loosen set screw (2) from the bottom of the handle, remove accent (3), replace with new accent, tighten set screw (2), replace handle on faucet and tighten set screw (1).
Here is the link for the installation instruction:
http://www.deltafaucet.com/media/MandI/40033RevC.pdf
To remove window crank handle,
pull the handle toward you exposing the
window crank handle retaining clip on the
back side of the window crank handle. Using
your trim panel removal tool, apply pressure
to the window crank handle retaining clip to
remove the crank handle.
HOW TO REMOVE DOOR
HANDLES (LFX25960
To move refrigerator through a house door, it may
be necessary to remove the refrigerator door handles.
1. Removing Refrigerator
Handle
Grasp the handle tightly with
both hands and slide the handle up (this may require some force).
The keyhole slots on the back of
the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if
you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble
handle, you must push or pull with reasonable force.
2. Removing
Freezer Drawer Handle
Press the handle
against door first.
Grasp the handle
tightly with both hands and slide the handle to right (this may require some force).
the back of the handle allow the handle to separate from the mounting screws.
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
