Garden Logo
p
peter forrest Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size socket do i need to take off the cylinder or is it a special tool
Josh Canaday
Level 3:
Master:
  • Master 444 Answers
  • Posted on Jan 24, 2014
Josh Canaday
Master
Level 3:
Master:
Answers
444
Questions
Helped
138053
Points
1365
To remove the jug from the power head youll need a stihl tool, aka a torx driver.
2001 Buick Century Custom harmonic balancer bolt size?
This is the bolt, but the answer is the size of the socket that fits it. If you don't have a full set of sockets and wrenches, doing job is impossible. If it is oversize, and I don't think it is, you can get larger specialized tool from Autozone for free and just a small returnable deposit.
https://www.google.com/search?q=2001+Buick+Century+Custom+harmonic+balancer+bolt
1helpful
I just ask the question about tools to change the harmonic balancer the vehicle is a '92 Oldsmobile Cutlass Ciera 6 cylinder with a 3.3 motor.
This vehicle will require a special puller to remove the balancer once the crankbolt is removed. This bolt is usually 21mm or 22mm in socket size if I remember. You will have to remove the wheel and inner splash sheild to access the bolt. The puller can usually be rented from most auto supply stores for a small fee.
What tool is used to open the head bolts on a citroen xsara picasso
Special tool like Torx key. Use the ones that can be inserted into a size 10mm bolt socket. I think it's size T50.
1helpful
3answers
Replace spark plugs
The OE Autolite plugs installed in the Navigator use a 9/16 inch
socket, which is most exactly the same diameter as the thread area, which makes it look round in the hole. The Champion 7989 uses a 5/8 Spark Plug Socket, which is one of two "standard" plug sizes. The other "standard" plug size is 3/4 inch, which is not used very widely any more.
2helpful
Peugeot 207 spark plug size
8 mm according to my Pugeot and Mercedes reference.
I would have a complete set of 3/8" Metrics 12 pt sockets on hand to be sure at the time of doing the job as sometimes our manuals are not exact due to the many variables.
It shows a thin walled 12 point metric. I know my BMW uses a 10MM thin walled for the irridium plugs.
You can find the tool mentioned on eBay, it has a special clip to retain the plug as you extract & insert it.
Mercedes M156 engine, Peugeot 207 and 307, Renault 1.2 16v SPARK PLUG SOCKET 8MM Item #120884075060.
2answers
Do i need special tools to replace 2001 Pontiac Aztek Oxygen Sensor
No special tools are needed, just use a open end wrench or adjustable wrench.
Want to replace drive sprocket on motor how do you get it off
Your sportster is actually pretty easy to change the front sprocket on. On the right side of the bike, you'll see the rear brake master cylinder. The master cylinder must come off as well as the plate that the master cylinder sits on. To get this off, you'll have ot remove the brake pedal and the exhaust system.
Once you get the plate off, you'll need some special tools to remove and replace the front sprocket. You'll need a special socket to remove the large nut holding the sprocket on and a special device made to hold the sprocket so you can get the nut off and then back on with the proper torque.
In addition to changing the front sprocket, you'll also have to change the final drive belt to match the size of the rear sprocket and front sprocket combination.
Good Luck
Steve
2answers
Rookie needs help. I am trying to remove my front caliper on my 2006 Sportster 1200c. The two bolts to remove the caliper are not something i've seen before, a standard or metric (nnooooo) socket didnt...
u need a 12 point socket, looks like a 12 side star. sould be able to find at sears in the craftsman sockets. get a small set, there is a couple different sizes on the bike. ask for 12 point socket set.
1helpful
What size socket or tool is needed to remove the module from distibutor
Most of those either take a 5.5mm or a special ford module socket...you can get either at most any good parts store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2helpful
2answers
Rear Brake caliper what are the size of the Guide Pins?
for the most part its a 10-MM and try these website to see if they have any information for you www.autozone.com and www.alldatadiy.com if all fails stop by your local library and get your hands on a haynes auto repair manual for your van.
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
