Question about Whirlpool GB2SHDXP Bottom Freezer Refrigerator
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Initial problem was hearing a fan running constantly. After emptying everything, found freezer was heavily iced up. With back cover removed, a fan and compressor are evident. Ran all service tests, all checked out except possibly test 2 (compressor/condenser fan test). During test 2, when toggling between on/off settings, a distinct click emits from frig/freezer control, but nothing shuts off. Freezer was completely disassembled and defrosted, no damage to wiring or controls was visible. There is no obstruction to air flow and no dust or pet hair accumulation. Frig gets cold without freezing. Freezer keeps food frozen. Freezer fan works. Frig damper opens and closes. Both thermistors pass service tests. Forced defrost service test appears to function properly (I can hear the "crackling" of expansion/contraction), but have not checked actual voltages since I don't know test points. Serial number is ECT5010234. Frankly, I cannot afford a new frig right now.
    Master:
  • 796 Answers
Buy a used fridge on ebay, they are very cheap.
Posted on Dec 21, 2013
SOURCE:
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
cj2176
  • 520 Answers
SOURCE: freezer runs constantly and ices up
It sounds like the thermostat has failed. Have it replaced and it should take care of your problem. Hope this helps, good luck!
Posted on Sep 02, 2009
  • 2187 Answers
SOURCE: Ice forms in on the back panel in the freezer;
Make sure that when you have removed the ice you also cleaned out the unit especially the freezer and the drains. Clogging due to dirt is sometimes the cause of coils to freeze up. I would advise to have the thermistor checked. I am unsure if your unit has auto defrosting capabilities, if it has you may want to have the circuit checked out.
Posted on Sep 06, 2009
  • 1218 Answers
SOURCE: line and air flow box between freezer and frig
If the fan is running in the freezer compartment, temperatiure is normal, and no frost is building up on the back panel in the freezer panel, then there is a good chance the return air shutes in the fresh food compartment are blocked with ice. The return ducting is just as important as the the supply shute which you melted out. Difficult if not impossible to see.
My recomendation is to empty, unplug and air dry the whole machine preferably with a fan blowing air into the fresh food compartment.
Haste makes waste with this machine. Using heat can cause the plastic shutes to melt and distort.
Should be defrosted in this manner for 24 hours.
Restart and give the machine 24 hours to recover. Common problem with Whirlpool products.
P.S. Check to see if lights go out when closing fridge door. In fact this should be your first step. Jack
Posted on Nov 02, 2009
heatman101
  • 43501 Answers
SOURCE: The Refrigerator is 2 years old, and is no longer
Hi Chris,
The problem would seem to be that you developed a small leak in the refrigeration system. This is also assuming that you checked and cleaned the condenser coils which are underneath the fridge. Excessive dirt could also cause this, but from what you are describing I would say the problem is more then that and you have a leak...
The only other thing would be thermostat sensor issues, but then the compressor would be cycling and not running steady...
heatman101
Posted on May 18, 2011
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Freezer has constant noise. When we open freezer drawer, noise stops. Could this be the fan?
usually the fan runs with door open as well. how ever u may have a problem with fan hitting something if it has come loose or off its support bracket, if u have an ice build up in freezer usually due to defrost problem the fan may make funny noises also
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
My ice maker does not work but the freezer is only cooling to 20 degrees. I do have water at the door and do not seem to have an over frost issue. The control is nearly as cold as it will go and the...
evap fan runs when the compressor runs / so the unit is running most of the time . you may have dirty cond coils under neath or the fan by the compressor is not running . this cool the coils and promote cooling . ck them and clean them . mm hope this helps .. feed back pls ..
Dec 11, 2010 | Refrigerators
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Freezer works, fridge does not,runs constant though
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
May 15, 2009 | Electrolux Refrigerators
Noise at the top, constant
Are you saying you get the noise even when the refrigerator is not cooling? If you get the noise only when the refrigerator "runs", it is the fan as you suggest.
Apr 28, 2009 | Viking Professional VCBB363 Bottom Freezer...
Fan motor ???
ef452b7.jpg I will send another figure then instructions
Nov 19, 2008 | Whirlpool Refrigerators
Constant clicking from freezer fan that won't start
Could be the defrost cycle is not running properly and the fan has ice on it.
Oct 28, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Whirlpool GB2SHDXP Bottom Freezer Refrigerator Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
