Contributor
- Posted on May 16, 2009
Re: My Dell PowerEdge 400SC server seems to run OK but...
Hello..this is the solution if u want to go back run properly the unit.remove the memory card SDR,DDR1 or DDR2..try to clean all pin connector using the paper eraser.Good Luck..Thanks and GOD DAY..^_^
Thanks....that helped a memory issue but the system just kept on with a constant beep....I finally found a board in the PC that had a little speaker on it that was beeping....the card was RAID controller card and I had a bad hard drive.
There just wasn't much warning but that was it. I think the memory and the disk issue was just from dirt.
Thanks again
