My led power not on via remote control. Plz tell me salutation.
If all other buttons except power button on the remote control works, the fault should be of remote control. Its internal circuit will have a break; and is irreparable. If no buttons works, check the remote control for its infrared emission. For more information http://electronicshelponline.blogspot.com/. If the remote control is found faulty, buy a new one.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
