SOURCE: WHAT IS THE FUSER ASSEMBLY? hOW CAN i REMOVE PAPER JAM?
This is near the exit area right before copy exits into the tray or sorter It appiles heat and pressure to the copy as it goes between the upper and lower fuser rollers so that the toner melts into your copies and won"t rub off keeping the image from smearing Often the copies will be warm--this is normal.
SOURCE: ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
SOURCE: Jammed Paper - Canon PC860
You are almont there .There is also 2 clips that release the presure on the sides of the fuser to release the presure on the roller and remove the paper.
SOURCE: Canon IR C3220 paper jam problem showing in the
Check to see if the EJECT SWITCH is hung up or out of it's holder.
IR 2270, 0108 & 0207 jams your code is the fuser sensor but I would think about adjusting the loop esp if the paper is coming from an optional lower cassette.
FIRST THING I would do is replace the pads for the flapper figure 140 item 6 in parts manual. the two black foam pads were changed to a stronger white pad. These can cause your problem.
The updated pad number is fc9-4659 you need at least two . Plus you need to make sure the metal cover is on your registration sensor. fc7- 9370 ." http://www.copytechnet.com/forums/canon/68195-ir4570-paper-jam-duplex-mode.html
