I HAVE WNDOWS 7 I REPLACE XP HOME EDITION , EVERYTHING WAS OK WITH XP, BUT WHEN I PUT IT WINDOWS 7 I GET A PROBLEM WHIT THE RESOLUTION DISPLAYS , I HAVE A 640X480 AND I NEED 1920X1200 WHAT I CAN DO?
Right click on the desktop and a pop up menu will appear. Three items off the bottom select 'Screen Resolution' and click it. A new window will appear, in the centre are 4 options, choose the drop down menu (small black triangle) against Resolution. It will most likely be showing 640x480 in the window. Click the drop down menu and select your required resolution, the best one for your video card will have (recommended) against it. Click OK and wait for your screen to refresh. You should see a confirmation message asking to OK the change. If you do not see that DO NOT TOUCH any keys or buttons for a minute or so. If the screen went black and stayed that way you have chosen the wrong one. By leaving the keys alone for a minute, the display will automatically revert to the last setting thereby giving you the option to try a different setting. If you touch anything whilst the screen is black you may not see anything again, be warned!
SOURCE: runtime error 204 at 004027EC
try doing a restore to before you had the problem . windows 7 /vista and xp allows you to do a system restore . if you dont know how to do a restore check in your computer handbook . if you dont have 1 you can return to fixya we'll fixya
SOURCE: Windows 7 Pro 64 Bit and No Internet
It sounds to me like you need a new driver for the LAN adapter that is compatible with Windows 7 64 bit. Right click on Computer under the start menu, chose manage, and open the Device Manager applet. Look for your network card under Network adapters. Right click on your adapter and click on properties. Go to the driver tab and click on update driver. You can also try uninstalling the driver from there and then have the computer scan of new hardware from the device manager screen and let Windows reinstall the driver. Let me know what you find so I can help you further troubleshoot if this does not fix the problem.
SOURCE: I recently upgraded my HP Pavilion a6700y from
You can chat with a live person on hp.com who can provide you with the correct link to obtain the correct driver.
SOURCE: Opening Word 2007 changes my PC screen resolution to 640x480.
Right click on the shortcut you're using to startWord, and click on Properties. In the resulting dialog box click on the Compatibility tab. make sure none of the options to run in lower color or resolution are checked.
Also check the same thing on the winword.exe file that actually starts Word. It can be found in C:\Program Files\Microsoft Office\Office12
SOURCE: I have a compaq presario
1. SM Bus Controller: http://www.fileguru.com/apps/sm_bus_controller_driver_windows_xp
2. Video Graphics. http://download.cnet.com/windows/video-drivers/
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
32-bit
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
