I somehow locked my JVC DVD player door and the way I fixed it was to simply unplug the cord and put it back in and vola the door unlocked.
HI,
Try doing a hard reset.To do a hard reset unplug all the cords from the back of the unit for 4 hours,even the power cord.After 4hours. plug in all the cords again and then turn on your player.This should fix the issue.
SOURCE: DVD player is locked!
Unplug for 5 min then plug back in... now press and hold the powers button for 15 seconds...thts should fix ya!
SOURCE: my kids locked my rca dvd player model rc5220p
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
SOURCE: Locked dvd tray
Hi there, I just had the same problem with my daughter, looked in the manual and it says to hold down the stop button and press the eject button on the unit. That should unlock it, its the same procedure to lock it, in case you want to prevent you daughter from attempting to play biscuits!!
Regards, darren
SOURCE: Need to unlock my dvd player
I tried the solution p[osted by kuntrygurl and it worked for me! Use the forward and backward keys when it asks for a password, forward,backward,forward, backward
SOURCE: Dvd player Locked
there are two ways to unlock it.first is using the remote. the other is by opening your unit up and manually open the cd tray, then power on.if not, buying a universal remote won't help either, but bring it to a tech is the last option.
