Black blug
OPERATION
See Figures 1, 2 and 3
Fig. Fig. 1: MAP sensor location-2.4L engine
Fig. Fig. 2: MAP sensor location-3.0L engine
Fig. Fig. 3: MAP sensor location-3.3L and 3.8L engines
The PCM supplies 5 volts of direct current to the Manifold Absolute Pressure (MAP) sensor. The MAP sensor then converts the intake manifold pressure into voltage. The PCM monitors the MAP sensor output voltage. As vacuum increases, the MAP sensor voltage decreases proportionately. Also, as vacuum decreases, the MAP sensor voltage increases proportionally.
With the ignition key ON , before the engine is started, the PCM determines atmospheric air pressure from the MAP sensor voltage. While the engine operates, the PCM figures out intake manifold pressure from the MAP sensor voltage. Based on the MAP sensor voltage and inputs from other sensors, the PCM adjusts spark advance and the air/fuel ratio. The MAP sensor is mounted to the intake manifold, near the throttle body inlet to the manifold. The sensor connects electrically to the PCM.
TESTING
See Figures 4, 5, 6 and 7
Fig. Fig. 4: Disengage the MAP sensor connector-3.0L engine shown
WARNING
When testing the MAP sensor, make sure the harness wires do not become damaged by the test meter probes.
Fig. Fig. 5: MAP sensor connector terminal identifications: (A) 5-volt supply, (B) sensor signal, (C) ground-3.0L engine shown
Fig. Fig. 6: MAP sensor connector terminal identifications-2.4L, 3.3L and 3.8L engines
Fig. Fig. 7: Using a digital volt-ohmmeter, test the MAP sensor voltage-3.0L engine shown
REMOVAL & INSTALLATION
See Figures 1, 2, 3 and 4
The MAP sensor is mounted on the intake manifold near the throttle body inlet to the manifold.
Fig. Manifold Absolute Pressure (MAP) SCIP sensor location-2.0L engine
Fig. Manifold Absolute Pressure (MAP) TMAP sensor location-2.0L engine
Fig. Manifold Absolute Pressure (MAP) sensor location-2.2L & 2.4L engines
Fig. Manifold Absolute Pressure (MAP) connector end view-2.0L & 2.2L engines
Fig. Manifold Absolute Pressure (MAP) connector end view-2.4L engine
NOTE
All electrical components and accessories must be turned OFF, and allowed to power down.
