I think i explained the problem quite well, i need some codes, or another method or solution to my problem
2967,2901,2958,2941. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
SOURCE: philips universal remote codes for symphonics tv
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
10180,
10171,
11913,
11904
OK.
