Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
A
Anonymous Posted on Dec 20, 2013
F1 code flashing jenn-air wall oven - Jenn-Air SCE30600 Slide-In Electric Kitchen Range
5 Related Answers
Anonymous
  • 23 Answers
  • Posted on Jun 02, 2007
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Anonymous
  • Posted on Oct 10, 2009
SOURCE: F1-8
Problem fixed!!! Lowes is giving us a new stove!!!
Petroni0264
Bailey's Appliance Service
  • 222 Answers
  • Posted on Nov 04, 2009
SOURCE: Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Mike Carew
  • 969 Answers
  • Posted on Nov 12, 2009
SOURCE: jenn air jds8850aas f1-1 code and beeps when oven
http://www.applianceaid.com/fault_codes.html
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: jenn-air gas range probe light f1-10 code
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
3helpful
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
5helpful
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
1helpful
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
2helpful
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
1helpful
2answers
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
1helpful
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
My older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
