TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N Logo
A
Anonymous Posted on Dec 20, 2013
192 config 192168.1.1
2answers
192168 01 login
Pam- Have you connected directly via ether net cable when attempting to connect to that IP?
Connect to 192168 01
Click on Start(Windows button) > Run > type cmd and press enter. Type ipconfig and press enter. Make note of the default gateway address. Open a web browser and type this address in. Configure away.
Connect to 192168 21
You either need to provide a lot more information or call your internet service provider.
192168 11 login
connect your router to the computer with a straight through cable.go to your web browser and enter the default ip address of your router.
enter default password and enter setup screen.
contact me incase of any deficulty anywhere.
I have compaq presario 700 but having a problem with no audio or video sound
check if the Sound card drivers are insttaled, if not go to ma-config.com and scan , ant you'll find the missing drivers ;)
Peace!
I want audio driver for it
the best way to find it is to go to ma-config.com and scan so that the website identify your computer , thene it will list all the missing drivers and give a download link, its easy just folllow the website ;)
Wrong ip address. No fix w/ipconfig/renew
192. is the beginning of a default gateway IP address and is usually only assigned when you are using a router. I recommend connecting to your router.
12helpful
2answers
192.168.1.1 is not opening
192.168.1.1 its open but username password is not wrking, why. plz send solution
Wireless network compaq presario f700 not working
hmm..ok..open start control panel wireless configuration check to see that you're enabled. then back to control panel, network config or settings(depending on which operating system you use) right click on wireless icon, and repair it. let me know if this helps.
CANT ACCESS OPERATING SYSTEM
Restart the computer and repeatedly tap the F8 key. Try going in through "Safe Mode" or try restoring tho "The last config that worked"
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
