Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
K
KEN REESE Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed new carb kit, plug is getting sparkn install new plug and prime carb andf it doesn't fire
windsorguzzi
Level 3:
Master:
  • Master 796 Answers
  • Posted on Dec 21, 2013
windsorguzzi
Master
Level 3:
Master:
Answers
796
Questions
Helped
189438
Points
2084
Did you set the carb up after you installed the carb kit?
3 Related Answers
Anonymous
  • 2220 Answers
  • Posted on Nov 20, 2009
SOURCE: Husquvarna 45 starts up but back fires through the
All things are possible. The flywheel is keyed using a woodruff key. They rarely jump time. If the new coil meets the manufacturer's specification there is no logical reason for this. If my saw, my local Stihl dealer (Husky is closer, I prefer local Stihl mechanics) wold be providing a problem diagnosis/ repair estimate. Inform any mechinic about everything you have done to the saw.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Good Luck
Lou
puertobori
  • 7733 Answers
  • Posted on Nov 02, 2010
SOURCE: I had a new carb kit put in my saw.It was
Husqvarna Genuine Parts - Reliable Spare Parts for Homeowners
Anonymous
  • 9 Answers
  • Posted on Apr 17, 2012
SOURCE: put new carb. kit in and primed and run a for a few moments and dies would the float be to lean
welcome to: http://www.netetrader.com
The website wholesale for many kinds of
fashion shoes, like the nike,jordan,prada,****, also including the jeans,shirts,bags,hat and the decorations. All the
products are free shipping, and the the price is competitive, and also can accept the paypal payment.,after the payment, can
ship within short time.
free shipping
competitive price
any size available
accept the paypal
jordan shoes $32
nike shox $32
Christan Audigier bikini $23
Ed Hardy Bikini $23
Smful short_t-shirt_woman $15
ed hardy short_tank_woman $16
Sandal $32
christian louboutin $80
Sunglass $15
COACH_Necklace $27
handbag $33
AF tank woman $17
puma slipper woman $30
My HUSKEE Supreme model 12A-569K730. Won't turn over fresh oil, gas, new spark plug clean air filter. What else should I try?
is there a bowl with a screw on bottom attached to carb if so take the screw out an look for a tiny clogged pinhole on bottom .
if not then you'll likely need a carb kit the rubber is not working correctly an has air holes
take out the plug an let it hang is it sparking
prime it does it fire up any meaning a kit or cleaning
May 03, 2015 • Garden
1helpful
Troy-bilt storm 2840 fuel line not getting fuel to carburetor
Gasoline brakes down over time. What happens all the things the facilities uses to make gas separates and you end up with all the bad stuff. You may need to remove fuel tank and clean it out plus the carb may need the same thing done to. If you have to clean the carb get a rebuild kit. It's easy to rebuild but you may need to take the carb with you so they can get the numbers of it to make sure you get the right kit.
Nov 10, 2014 • Garden
2answers
Husqvarna k760 will not prime and/or run properly
It runs off the fuel from the priming cycle, so no fuel from impulse air/diaphram. Check impulse air line is properly connected, not cracked (leakin), else diaphram may need replaced (carb rebuild kit).
Dec 11, 2012 • Garden
1helpful
2answers
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 • Garden
1helpful
2answers
The motor turns over when I turn the key but it will not run. New battery, new plugs, new fuel line, and cleaned carbs. Fuel petcock was left open a couple times when I first got the bike. Has not been...
ARE YOU GETTING A SPARK AT ;PLUG REMOVE PLUG HOLD AGAINST ENGINE BLOCK TURN OVER ENGINE YOU WILL SEE SPARK OR FEEL IT IF YOUR UNLUCKY BE CARFUL IF NO SPARK TRY CHANGING SPARK PLUG LEADS COULD BE U/S GOOD LUCK [FROM THE AUTO ELECTRICIAN]
INSTALLED NEW CARBURETOR NOW WILL NOT START?
Assuming all gaskets and lines were installed properly, try priming it with a little gas directly into carb, or remove spark plug and put a little gas directly in cylinder and see if it picks it up. Sometimes for first start this is necessary.
1helpful
When i start it up and let it run for the 30-60 seconds then squeeze throttle it doesn't want to run. almost like it either starves or floods.
Definitely sounds like a fuel delivery issue. It may be time to install a diaghram kit or rebuild kit on the carb. The sensitive internal parts don't last forever. You can check for flooding immediately after by pulling the plug. If it is real wet, either the plug isn't firing to its full potential or the carb is indeed flooding.Those carb kits aren't too hard to install and you may be able to get by with just the cheaper diaghram kit.
Have to prime carburetor to start truck.
It is a good idea to replace the kit, and it is a matter of stripping the carb and taking note what you removed where and replacing with a new part. You should also check the spark plugs and timing. If the timing is out, the engine will also have difficulty starting.
2answers
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
