I usually turn off the heated dry on my dishwasher and just open the door when it's through to save energy, but now the heated dry button doesn't respond....the light won't go off when I push it. I tried the "reset" procedure described in another answer and it does nothing.
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
SOURCE: dishwasher not running
hello sir.....
is the Start/Resume indicator flashing?
Opening the door or interrupting the power stopped the cycle. Close the door and press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
may be the motor has stopped due to an overload....as you have mentioned...many of the buttons were pressed...
The motor automatically resets itself within a few minutes. If it does not restart, call for service.
In Canada, call 1-800-807-6777, or your nearest designated
service center.
In USA ..Call the Whirlpool Customer eXperience Center
toll free: 1-800-253-1301.
If you need further assistance, you can write to us with any
questions or concerns at:
Customer Interaction Centre
Whirlpool Canada LP
1901 Minnesota Court
Mississauga, Ontario L5N 3A7
SOURCE: problem with whirlpool dishwasher ADG957
Continuous flash with no pause is a Faulty NTC (temperature sensor)
Or according to whirlpool it might be that your keys are syticking.
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
SOURCE: The dishwasher won't start, its stuck, pots/pan
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
