Panasonic Lumix DMC-FX01 Digital Camera Logo
Posted on Dec 20, 2013
Pansonic lumix zs20 mode dial stuck
My camera is just over aear old and the mode dial is stuck. Its tight and will not move. Is there any way to fix it without shipping it in for repair?
1 Related Answer
Axel Gringmuth
  • 79 Answers
  • Posted on Apr 21, 2008
SOURCE: Panasonic Lumix DMC-FX01 Mode Dial stuck
email me and I forward the instruction in PDF: [email protected] . Replace the first X with a and last X with m in my email address.
I have a lumix DM-ZS20 and the lens barrel does not open. when on message reads turn off, turn on or system error(zoom) on camera set
If the camera is under warranty, use it, If not check for a local repair shop or go online to Lumix website for information o repairs and the costs.
1helpful
Dmc-zs20, I have a japanese version and I need it to display in english.
Press the MENU/SET button. Select Setup (should be the fourth item). Select the next-to-the-last item on the menu (the talking head icon).
2helpful
I have a Lumix DMC-LC50 When I turn it on it says: Mode dial is not in the proper position I tried everything
The mode dial is the knurled knob on the top of the camera - if you didn't already know. This same error message displayed when the knob is between selection. If you have moved the know to a valid position - where it stops in a detent, the message should clear from the display and be able to take pictures.
If moving the mode dial so that it rests in a detent and the message is still displayed, it indicates a problem with the switch inside the camera (that is operated when the mode dial is rotated). This is not a user serviceable part, and should be professionally repaired. I found United Camera to list a Mode Dial repair to be $42. there are plenty of others that can make this repair for you, too - this was simply the first I saw that had a price (I have never done business with nor am I affiliated with United Camera in any way).
I hope this is a good starting point for you & good luck. Please rate my reply - thanks.
1helpful
4answers
Lumix camera says mode dial is not in proper position
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
