1- Are you using distilled water? If yes then the machine cannot sense the water level in the boiler.
2- Where is the water that is being pumped going? If it is coming out the drain tray, then the solenoid for the group needs to be replaced.
If it is coming off the top of the boiler, Then the level probe is calling for water, in which case you will have to remove probe and clean with a wire brush.
