SOURCE: HP laserjet 3050 prints skewed vertically
250-sheet input tray (tray 1)
The input tray holds up to 250 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media
(25 mm (0.9 inch) or less stack height). Load media with the top forward and the side to be printed
facing down. To prevent jams and skewing, always adjust the side and rear media guides.
NOTE When you add new media, make sure that you remove all of the media from the input
tray and straighten the stack of new media. This helps to prevent multiple sheets of media
from feeding into the all-in-one, which can cause jams.
Hope this helps if not you may have a registration roller problem.
SOURCE: HP psc 2110 Printer keeps
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
SOURCE: hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
SOURCE: Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
SOURCE: My HP printer is printing out an extra page with
You need to check the mode your printer is printing in. It may be in diagnostic mode. Another reason for having an extra page with info. is the page isn't setup to print all info on one page. Run your setup allignments and testing options to get it all on one page. Hope this helps. -Jennifer
