Question about Pioneer VSX-305 Receiver
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Pioneer vsx-305 has a light buzzing sound, coming from speakers i believe, for a few years now. still puts out good sound. now i hit power button, i hear a clicking in the back left, but it won't power up to allow functions to work (radio, cd). also, the main display does not come on either showing radio channel or other function in use. my wife says she turned the unit on the shelf to see if speakers were attached to play some tunes and then it wouldn't turn on properly. now i see where it doesn't power up. red standby light on power button does disappear when I click power on, but i hear the click in the back and get nothing. unit about 8 years old.
    Brigadier General:
  • 8,546 Answers
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
  • Martin Gowers
    Martin Gowers Jul 25, 2014
    Sounds to me that it has got a power supply fault the buzz was probably a component starting to fail this will probably be only a resistor on the power supply there are normally four the same so replace them all at the same time as they only cost a few pence
  • 56 Answers
    New Friend:
Alright as odd as this solution may sound its worth the 5 seconds it would take to try it. My exact model receiver ran into the same problem. Standing the unit up on end on its left side restored power to the unit and it started functioning fully again. To the best of my searching and many hours poking around inside the unit it appears to be a connection problem with two of the larger capacitors inside the unit.
Posted on Jan 23, 2012
SOURCE:
I have a Sony TA-AX 301..powers up fine.. and can
Make sure your speakers are the correct impedance for the amp. They should be 8 Ohm.
Connect them to the Speakers A sockets on the back of the amp.
Set the Speaker selector switch on the amp's front to Speaker A
Connect your source as detailed in the other answers.
Set the graphic EQ to either Off or Flat or put all the sliders to the middle position.
Apart from setting the volume on the amp, that should be it. If there's still no sound then you should recheck your wiring and input selection (make sure the red & white are connected to an IN and not and OUT on the amp). KIf there's still no sound then either the speakers or the amp (or both) have a fault.
Sep 16, 2014 | Audio Players & Recorders
Display message "DSP NG"
Hi pay attention to do all interconnections right
You can get help dowlowding a low cost service manual at link below:
http://www.smpcshop.com/VSX-D414-VSX-D512-p-5216.html
Have a nice day and Good luck
Feb 21, 2008 | Pioneer VSX-D511 Receiver
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
How can I connect an HD LCD tv to an ancient (I think 1980s) Pioneer Receiver Model VSX-305? The receiver is in great condition, and I'd rather not replace it. I have Bose speakers connected to i
I have never seen RCA to digital conversion, and if it did exist you would have to convert from digital to analog in order for this to work, the sound quality would be degraded and unreliable, plus sound level would drop.
Mar 20, 2012 | Pioneer VSX-305 Receiver
After many years of great service, ht\\the display now shows "overload" after about 5-10 seconds of playing. Sound is interrupted. Any help would be appreciated.
if the unit detects a speaker or speaker wire short it will go into protect..will it stay on with no speakers attached? if so theirs a good chance the unit is ok and 1 or speakers or their wires is at fault
Aug 30, 2010 | Pioneer VSX-305 Receiver
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
When push the power button, I can hear a relay click but the unit will not power up. I took the cover off and fuses are good. Can't find anything in the trouble shooting section of the manual. What do you...
When the unit functions correctly, you should hear 2 clicks. The first is the power relay that "starts" the unit. The second is the speaker protection relay that will kick in the speaker connection. If you do not hear the second click, the unit is in protect mode. This means that a problem was detected in the amp section and the unit is prevented from connecting the speakers. This is done to prevent further damage. Typically the output transistors fail and cause this. Expect a parts cost in the $25-$50 range for this repair.
Dan
Sep 30, 2009 | Yamaha RX-V1500 Receiver
749 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
