The Imac won't install the HP software that came with the printer, it has to do with the architecture. However, the Imac G5 does recognize the printer wireless but when you want to print something the Imac says that the printer is offline even when it's on.
SOURCE: ''Check Print Cartridge'' light keeps blinking On HP psc 1210v AIO
Bad ink Cartridge, I got a new cartridge and within a week had the same problem replaced the cartridge and problem solved. To bad these things are so expensive.
SOURCE: Printer offline HP 4500 series wireless.
Hope this help. Please
Rate My Response! Thanks!
PREM
SOURCE: HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
SOURCE: HP Deskjet 3500 series, my printer keeps telling
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
SOURCE: i have just got a new HP wireless printer, i have
I Like the other's had the same problem with my HP J4680 and did what LMJenkins did. I have Windows 7, and it varied slightly:
-From the "windows button" click "Device and Printers".
-Right click on the HP officejet J4680 "printer properties" and go to "ports"
-Enter the IP address of the printer (192.168.1.1(xx)) and click enter
-windows 7 will do the rest. When it's done make sure that port is clicked (named your IP address), and it should work.
I'd like to thank LMJenkins for helping me solve my problem!!
http://www.jimdeluca.com
