Sharp R-1480 Microwave Oven Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp R-1480 Microwave Oven made craking noise-now does not heat
Sharp R-1480 Microwave Oven made like a popping noise. I stopped it, when I started again sounds as if it were working but louder, and it is it not heating at all
Anonymous
Level 2:
  • Expert 180 Answers
  • Posted on May 16, 2009
Anonymous
Expert
Level 2:
Answers
180
Questions
0
Helped
54906
Points
396
Replace the magnetron and check the wave guide also.
A loud snap noise. seems to run but doesn't heat up
If it does not heat, then the problem is the magnetron circuit has failed. Would recommend that you have a qualified service person throubleshoot/repair it. One note, if the magnetron itself has failed, then buy yourself a new oven, since the parts cost is almost as much as a new oven. Sorry.
1helpful
2answers
Sharpe model R-1480 not heating (it sounds a little louder)
A loud sort of "groaning" noise and no heat is the sign of a bad magnetron tube. The magnetron is the microwave source, and when they go bad it's usually time to replace the oven. Most microwave repairs, especially a magnetron replacement, should be left to professionals. There are lethal voltages under the cover, and the chance of microwave leakage if the repair isn't done properly. With the price of a replacement tube and labor for the repair, it's often doesn't cost much more (and sometimes even less!) to buy a new oven.
Sorry I can't give you a more positive answer, but thanks for using Fixya!
Oven does not heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
My microwave oven (Sharp R-9h58) is not heating offen
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhfkj
Sharp r96st stops at 1 sec and halts whilst preheating oven
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
SHARP MICROWAVE R-1611 MADE VERY LOUD POP NOISE. NOW IT WON'T HEAT
20 A fuse inside m/w is out. The problem could be with HV condenser, one of the door switches shorted, computer board, magnetron. Needs technician to take a look on it.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
