Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
Posted on May 15, 2009
Water will not drain
Whirlpool dishwasher will not drain. It is only 2 years old. I pressed the drain/cancel button does not drain but i hear a motor. I did a complete wash cycle and still will not drain. thanks, yvonne
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
748
Points
1helpful
My whirlpool gold dishwasher is only 2 years old. It will fill with water but it just sits and makes a clicking noise when its supposed to be washing. It drains fine when I push the cancel button.
sounds like there is either a loose wire or bad switch on the water flow pump, not the drain pump What is the model number of the unit that your working on?
1helpful
Whirlpool dishwasher du920pfgq3 will not drain
If you hear the drain motor running but water not draining then there appears to be a blockage in the drain sump or hose. Assuming your kitchen drain is clear you will have to check filters inside the dishwasher and worst the drain pump.
If you do not hear drain motor running then the drain motor needs to be checked.
Check part locations at this site
http://www.appliancepartspros.com/parts-for-whirlpool-du920pfgq3.html
Apr 22, 2014 • Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 • Dishwashers
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
1helpful
Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
