Question about Pride Health & Beauty
Pride victory 10 beeps fast 10 times and slow 7
When starting out scooter beeps fast 10 times and slow 7 times goes very slow
    New Friend:
    Problem Solver:
  • 15 Answers
This is not good news. Sorry See the following link. Pride Mobility INFMANU1773 Operation Instructions Manual Page 16 Fault...
Posted on Apr 18, 2014
SOURCE:
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
dromtonpa
  • 40 Answers
SOURCE: The scooter will just start beeping 7 times and then won't go.
Call pride. That is under warranty. The will replace it.
Posted on Apr 06, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
  • 177 Answers
SOURCE: 7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Posted on Jul 09, 2010
wcdoc1953
  • 280 Answers
SOURCE: I HAVE A PRIDE 3
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Posted on Jan 20, 2011
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
Pride victory 9 beeping 7 times won't Move
Go to Pride mobility web page and get the manual for your model . The codes and their meanings are described in the manual
Sep 23, 2014 | Health & Beauty
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
What does the 7 beep code mean on my Victory Pride 10 mean when I turn the key on ?
Hi , 7 bleeps is the throttle pot error , either a calibration problem or a faulty pot, i can help you , please contact me
Regards
Rob
www.gewizrepairs.co.uk
Jul 11, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
5 slow beeps
check your charger - or your battery or both - my thought is the charging unit failed and is not charging to full battery
Feb 23, 2014 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
361 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
