I tried to unlock my SGH-A707 phone by this code #7465625*638*59258259* (the unlock code 59258259 was given by the store in California were it was bought) , but what came out is "Phone Freeze SIM Unavailable Please Contact Service Provider". Can you kindly help me unlock my phone. Thank you very much
After MUCH research, going to a local unlocker, calling AT&T and reading extensively about this online, I found the best solution:
1. Call Samsung Technical Support for Mobile phones: 888-987-HELP
2. Choose the right tele-prompt options that forward you to a live agent (ie do not choose PIN lock code or PUK code or such as they wont connect you)
3. Explain to the agent you have a "PHONE LOCK" and that no code will work an ATT told you to send it in to be "RE-FLASHED"
4. They take down your info, name address etc. and give you an RMA number. Follow the instructions to the TEE. Send in the phone (without batter and back cover to the address they give you in Plano, TX).
5. MAKE SURE to write the RMA number on the front and back of package.
6. Get your phone back like brand new!
My phone didn't much any units of cellphone grrr
i cant find the way to unlock my cellphone
Try entering the PUK
Hi, how could i unlock my samsung GT 15503 after few attempts and it wont accept my gmail acct. i forgot the pattern
Hi, I had the same problem, call 1800SAMSUNG and then go throught their steps to get to the phone help line and then they will ask you to send it in to flash. Its FREE. But shipping costs arouhnd $7.20.
I tried to unlock my SGH-A867 phone by this code #7465625*638*03579315#the unlock code 03579315 given by the online unlock code were it was bought) , but what came out is "Phone Freeze SIM Unavailable Please Contact Service Provider". Can you kindly help me unlock my phone. Thank you very much Thank you very much for helping me out
Its a alltel phone with verizon services
an i want to switch back to alltel
My Z170 s phone freeze. plz help me to fix this. tanx
Tritried to down lode music from computer and phone froze up just the sisign of the Iphone is on screen and the atachment sign nothing is working
SOURCE: Phone Freeze
hi there maybe i can help
insert a different sim to your phone then
input this code: *2767*3855# wait till it reboot
now your phone is open next input this
code: *7465625*638*00000000*00000000#
next again input another
code: #7465625*638*59258259#
finish now your phone is permanently unlock.
feel free to use any sim...... ok!
* if the second code you input, didn't work go dierictly to the last code ok......
peace!
SOURCE: phone freeze unlock code
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000#
If your phone says wrong password, turn your phone off and put in an
unaccepted Sim Card into the phone (A sim card from another Service
Provider) and then start the process over again. If it says wrong
password even with the wrong Sim card, then you have reached your
second attempt, Do NOT try it again. Instead, go to Ebay and purchase
an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now
that you know your phone's unlock code, (00000000) you can use the
following codes to unlock individual locks on your phone (Where you see
the word Code you will put in your new unlock code, which is now
00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
have a look at a similar manual; may help
http://www.techteam.gr/mobile/specs/guides/SamsungSGH-E370.pdf
Hi ,
you can download unlock client from below site
http://www.mobile2mobile.net/unlock/Remo...
http://www.mobile2mobile.net/unlock/RemoteunlockingSamsung.htm?gclid=CLzQwIOBqYsCFQ-Wbgod2n3IjQ
PLEASE RATE ME...........................................
I HAVE SCH-S109 CDMA MOBILE PHONE & I WANT TO UNLOCK IT PLS HELP
the phone says phone lock and i don't know the code to unlock it. my son said he didn't put a code on it
My phone was locked on "Phone Lock" and I do not know the password.
i received an a707 from a friend and when i tried to unlock it i recieved the message "phone is freeze deactivation failed"
have the same problem.
Tried to unlock the phone (using same codes) for international travel.
Carrier - Cingular unable to help
my phone is lock need password can any one help me
i am trying to unlock a samsung sgh a707 ive tired everything please help me.
the same thing happened ands now my phone is frozen
i bought the phone with a code in it don't know the first security code to unlock phone can you help me
phone freeze
SIM unavailable please contact service provider
my phone sumsung sgh-a707at&t sendit to me from the state has the same problim it says phone freeze simunaviable please how can you help me work this phone in middle east thnx
my phone say freeze
my friend took my phone and changed the code so now my phone is locked and i cant get into it.
phone freeze
i have another cell phone its a Samsung SGH-A707 Sync and its on phone freeze will ya help me plz i will be more apretiated.... ty
My SGH-A707 was purchased in the States - at&t network - its network locked, i tried to unlock it using the unlock code #7465625*638*59258259*, however, the phone went in Phone Freeze. In live in the South Pacific, specifically Papua New Guinea and would like to use it here. Can you help me unfreeze the phone and unlock the network so i can use it on our mobile network.
Hy all, my SGH-L760 say phone is freez. can anyone help me. please please
I entered the unlock code for a Samsung SGH-707, cingular and got a phone freeze sim unavailable, contact service provider. Help!
tried to unlock my a707 and it comes up freeze mode. can some one tell me what to do step by step.
phone freeze sim unavailable contact service provider
phone is asking for Puk code.
35310301271601002
Hi
My cell phone Samsung SGH A707 sync is hard locked, its popup with “Phone
Freeze, SIM unavailable please contact service provider”. What can I do about
it? I have received all kind of unlock codes and it haze cost me nearly more
than my cell phone. So if you have a solution for me please let me know.
Thank you
mi telefono al encenderlo me pone phone freeze sim no disponible preguntar a proveedor de servicios mi movil es un samsung z240 porfavor ayudarme
help me out have the same problem
SGH-L760
It says Phone Freeze SIM Unavailable Please Contact Service Provider
i have a samsung z400 it has phone freeze pleease can you help me
I HAVE SAME PROBLEM
HOW DO I UNLOCK MY SGH-A707 THE NETWORK LOCK
same problem
pohytvuik
how do you get the puk code for a samsung m150
same thing happened to me, i got a new sim and when i put it into my SGH-A707 is sayed "Phone Freese, SIM unavailable Please contact serive provider" and the sim works fine on other phones, what do i do?
