We've set the fax to print document, but when a fax is received, we don't know where it goes. it doesn't print it, and we can't find it on the computer anywhere - where is it!
Fax machines can be set to store documents, print docs or do both. If you set it to only print received faxes, it will try to print and give you some kind of error it if fails (e.g. no paper). Did you get an error? if not it either is set to store and not print, or it didnt store it and you have lost it. From the menus on the Epson, look for where items may be stored e.g. 'store' or 'mailbox' and check if there is any doc in there.
SOURCE: Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
SOURCE: Error 0495 - Receiving Faxes
Might be a problem with speed of the fax. See related question.
SOURCE: Fax Receives but does not print
You have a known issue with your unit, the unit will require a firmware update. The issue is known to epson and they should fix it under warranty. Contact your local epson service centre or contact epson direct in your country. If they try to charge you, scream loudly at them, advising them that this is a known issue with this model and they are obliged to repair it. You will find they will fix it without too much objection.
Gremlin 11
SOURCE: what are the settings to receive a fax on epson
Every fax will have a setting to stop and start the ability to receive faxes. Without your model number I can't guide you to the exact place, but look in your manual, under SETUP.
Good Luck
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
The machine cannot send or receive faxes when the power is turned off.
If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
Open the Document Tray.
Open the Document Feeder Cover.
With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
Close the Document Tray. speed printer service
